Re: Good compression for Honda BF5?
Here is the answer to inform anyone that has the same question I did.  120psi is about a high a compression you will get with a Honda bh5.  If it is below 70psi then you should probably do a leak down test to find a possible problem.  Mine is 80psi and the Honda Technician told me that it is fine and pulling the motor apart is not necessary, it still has a lot of life left in it.
