Well folks, I ran across a strange one while working on a motor my brother-in-law just bought... it's a 1972, 6hp, 50th anniv series. Like new.
BIL couldn't get it started after he bought it. So, I checked it out, cleaned the carb (stuck float wouldn't allow gas to bowl) got it running, took to lake to test at WOT. Wouldn't get to RPM at WOT. I assumed clogged high speed jet. Cleaned carb and installed a kit. Will run like a champ in the barrel until I put the cover on. With the cover on it won't get to RPM.
With the cover off it will.
I held the throttle at WO but the motor was running about half WO-RPM.
I reached around and unlatched the cover, raised up a bit and the motor sped up to what seemed right (hard to tell exactly in the barrel test).
Latch the cover back down and it slows down after a few seconds.
Have anyone out there head of / dealt with a problem with these motors where the cover fits so tight that it can't draw enough air through what few other holes are there from manufacturing ????
Have I overlooked something while rebuilding the carb?
Ideas to correct this ?
