specialk
- Aug 20, 2008
- 23
I have a couple of questions for the good people here. First the background.
- 2008 Glastron GT 185. 18.5 feet approximately 2500 pounds.
- Volvo 4.3 GL 190 HP
- Volvo drive 1.79 : 1
- OEM Volvo prop 14.25 X 23 pitch aluminum.
- total weight of people and gear about 500 pounds.
- all testing @ about 800 feet elevation above sea level and between 70 - 80 F.
- will make multiple runs and find the average speed. All speeds GPS verified.
Results in past years:
- plane in approximately 3 seconds.
- MPH matches RPM from 3000 - 4000 RPM. Meaning 3600 RPM = 36 MPH.
- Top speed 51 MPH @ 4600 RPM.
- Top speed if wife sits on back bench seat instead of front seat 52 MPH @ 4700 RPM. Can trim just a hair more to get more hull out of water.
Aluminum prop appears rough on the ends of the blades like the prop was somewhat sandblasted and pitted. So I tested recently.
Recent results:
- MPH 1 less between 3000 - 4000 RPM. 3600 RPM = about 35MPH.
- Top speed 50 MPH @ 4800 RPM. No matter where the wife sits or how many runs.
Questions:
- is it possible the prop being aluminum can wear enough to show a minor drop in performance?
As we only wakeboard and tube the boat does well for that. If there is a performance gain I would look for it would be for more top end speed.
- as the OEM Volvo aluminum prop appears well balanced for planing and speed reaching 50 MPH, is it worth trying a stainless prop or would the gains be minor? I am not sure a 1-2 MPH gain on the top would be worth more risk of outdrive damage if the prop hit something.
Recent results:
Questions:
