gm mercruiser 120
creeker
hi sort of a new boater and i need a parts motor to rebuil mine or if any one knows were i can get parts i need things such as outdrive, fuel pump, and new harnesses my motor is either an 88 or 89 it is carburated it is an alfa 1 outdrive im not sure wether or not its a 3.1 or a 3.4
Don S
Re: gm mercruiser 120
dougrussell.com <br />It has all the parts breakdowns. Your engine is close to the top of the list. Your drive is near the bottom.
rabidfish
I have them also... email me if you need something.
creeker
hey thanks alot do you know were i could i find a used outdrive or a used blown motor for parts?
tommays
cr<br /><br />ebay but you really need to no what your buying a lot of things dont match up from different years<br /><br />and with quality you need to be carefull to check it<br /><br /><br />tommays
Your going to have to do somemore Digging to find out Exactly What you have Now................<br /><br />I Thought that the 2.5l had been dropped from the line by 88.... <br />I could be Wrong..... But that's what a Merc. 120 would be........<br /><br />There is NO 3.1ls......... But, Of Course there Is the Lovely Mercruiser 470..............<br /><br /><br />Pull up the keyboard,+ Tell us Everything you Know about your new Boat..........<br />Somebody here will figure out What you've got,+ What you'll need.............<br />Got any Pic.s you can post ????<br /><br />And,........... Welcome to the forums here at iboats...........
trog100
the 2.5 got dropped in 88/89.. from 89 to 94 the 3.0L as opposed to the 3.0LX used the old 2.5 head for reasons unknown to me.. they either had loads of 2.5 head bits they wanted to use up or still wanted to pretend they still had a 120 horse motor in their line up.. dunno i am only surmising the reason for something that seems weird to me..<br /><br />i would guess that quite a few 120.. 140.. 3.0L and 3.0LX bits are interchangeable hard to say exactly what thow... the 120 was a 2.5 litre and the 140 a 3.0 litre.. they changed the way the horsepower was rated to at the flywheel which lowered it... and at the same time the way the engines were named.. they got named by capacity rather than horsepower..<br /><br />trog100<br /><br />ps.. the 3.0LX i mentioned might be 3.0LS.. i am quoting from memory.. which aint that good.. he he
Don S
creeker, if you have a Mercruiser serial number for your engine, we can find out Exactly what you have.
jimmythekid
3.1 and 3.4 engines are used in cars, both of which are based on the original 2.8. Cast iron blocks with aluminum heads. That combo wouldn't last long in a boat. if you have a V6 you most likely have a 4.3 litre.
