I have a 89 mariner 100 hp serial#C135659.No fire to plugs.In pulling the flywheel (stator)off I had to whack the puller a few times to break it loose.I saw that 2 magnets had come un-glued .I don't know if I did it or not.For the last few times out it was very bad about not starting until it just would not run.Would loose magnets cause the motor to act like that.What I really need to know is what glue to use on the magnets.JBWELD says theirs will NOT work.I have heard that loctite blackmax might work.Loctite has 3 new ones out but can not find them(gluemymagnet.com).Any help would be appreciated.....THANKS...dargel167
