Glue for the letter "E"?
Expidia
So my Wife's Saab 9-5 has the letters SE on the side and the top part of the plastic letter E was hanging off.
I have plenty of glues, but don't want to take a chance and use one and make the paint blister from some type of reaction with the glue.
I know they come new with a sticky back foam on them. Should I hunt around at an auto parts store and see if they sell that stuff or is there something else I can use that won't harm the finsh yet can be removed if need be?
Thx
TilliamWe
Banned
Re: Glue for the letter "E"?
Not hard to hunt, 3M sells "moulding tape" or some similiarly named form of a "2 sided sticky foam." That's what I would use.
WizeOne
Great stuff. Very secure. Chances are that you will find many other uses for the roll. It is a med gray color tape with a pinkish plastic pull off cover strip.
It is probably available at most autoparts stores or at least one that sell body shop supplies.
180shabah
Ditto - moulding/emblem tape is great stuff. You will find other uses for the rest of the roll. It is available at any auto parts store and many walmarts.
Tim Frank
Even better is a 3M Moulding and Emblem adhesive...comes in a tube and is less obtrusive than the tape for something like the letters you describe.
cr2k
I know the grey double sided tape works great. I put 4 quarter in by quarter in squares on a 6 pound battery to hold my RC plane starter on (thats 1 sq. in only) and after 3 years it stuck so good the top of the battery started coming off.
jay_merrill
Double sided carpet tape, cut to shape, would probably work.
dgopetactical
ditto with the 3m molding adhesive<<< 3m molding foam tape would be my first choice and the 3m liquid/gel would be second....I have tried out of the toolbox adhesive before with poor results goop etc.....The carpet tape thing is a realy great idea in a pinch/temp emergency repair but I dont think it will last long it dont hold up to moisture good.
Denny
