Take Flight
- Apr 16, 2012
- 2
Glastron SX 175 with the Volvo Penta 3.0GLP-C
So this has happened twice...the engine alarm is sounding, but is barely audible. When the ignition is on and the engine isn't running, it is loud & clear. But then when the engine starts, the alarm continues going off only it's very half-hearted & weak sounding.
Guages all read normal, and both times I ended up disconnecting the buzzer and running the boat without issues for several hours.
After the first time, several weeks ago, I plugged the buzzer back in and didn't experience this issue the next few times we went on the boat. Then it all the sudden popped up again.
Grounding issue? Should I be looking at the riser sensor since the oil & temp are apparently still fine?
