Git Rot Info
Peter Chom
I have some rot in boats transom and was looking at using git rot, is this product as good as they say it is ?. Also is there any publisized procedure for this type of rot repair at to methods and user experience.<br /><br />Thanks in advance<br /><br /><br />Peter C.
crazy charlie
Re: Git Rot Info
It works great providing you strictly follow the directions.If you stray from them and lock in some moisture,you will accelerate the rotting in the sound areas.Charlie
Solittle
Re: Git Rot Info
Best bet to get the best info is to hop over to the Boat Restoration Section and go to the red Search at the top of the page. Try entering "git rot" for a search argument. Also try "anti freeze" for a search argument.<br /><br />Rot, as I understand it, is a fungus that grows in wet or damp wood. The only thing that I know that will kill the fungus is, believe it or not, automotive antifreeze. I used it for rot under a Formica counter top in my patio last year and it worked. I shot the antifreeze into the wood with a hypodermic needle used for horses. While it killed the rot the damage had already been done and the rotten wood is still there but at least it is not spreading.<br /><br />I used git rot on a boat floor many years ago and thought it was a waste of money. If you have rot there is only one way to do it right and that is to bite the bullet and redo the floor. Either way the Boat Restoration is the place to go for info.
Lou C
Re: Git Rot Info
Check out www.rotdoctor.com<br />they have a lot of info about how to repair rot. Sometimes if it is minor you can use their Clear Penetrating Epoxy Sealer (CPES) and layup and laminating resin to repair it. But if it is extensive and in a high stress area, new wood is the best way to make a lasting repair. You can use the CPES to seal the new wood to keep it from wicking up moisture. I used their stuff in a floor repair job and it came out well. Cut out all the old wood I could remove, treated the rest with multiple coatings of CPES, and the laminating resin, laminated in patch panels, and finished it off with their epoxy filler. Expensive stuff but good.
