gimble assembly mounting..
phragle
I just rebuilt the transom on a 77 nova 250 and am putting the gimble/transom assemblies back on..ordered new o-rings for it (where the assembly meets the hull) do I want to use any kind of sealant on it?? if so what?? rtv?? 4200?? caulk?? thanks.
studlymandingo
Re: gimble assembly mounting..
Personally I wouldn't use a sealant on the o-rings. However, I would recommend using some silicone lubricant gel be put on the rings before the install. It will give a good seal.<br /><br />Welcome to iboats. This is a great forum to help you along as you get your rig together.
deejaycee_2000
Use sealant on absolutely everything to do with the transom ... all holes bolts etc ... any silicone will actually work, but try to use a clear cilicone, you can by marine cilicone at any hardware shop ....
