First post- I recently bought a 2005 Four Winns Horizon 200 with a Volvo Penta 5.0 GXI-E and SX-M Drive. I doing my first service I pulled the drive found water in the gimbel bellows and roughness in the gimel bearing. Inserted the VP alignment tool to check alignment before I touched anything. The tool was difficult to insert to full depth (had to wiggle it and use both hands pushing to insert the alignment tool). I replaced the bearing reinserted the greased alignment tool ( I've been reading the forums extensively for service tips) and it went in all the way but again it took effort to do so.
In trying to re-install the drive I can get the drive splines to mesh but the drive doesn't go in far enough to allow the 6 bolts to start threading.
My question is how much force is required to reinstall? I have replaced clutches on vehicles and when everything is aligned everything slides together with very little effort. What I am experiencing here is significantly harder than the clutch scenario.
Any advice would be appreciated as I don't yet have a "feel" for what I should be expecting. Thanks
