Re: gimbal bearing
Simon,<br /><br />The advantage of removing the drive is that as you push the grease in through the nipple you can see when all the old grease has been removed and clean it from the area then rotate the gimbal bearing by hand and repeat. You can do this until all the old grease is removed and the bearing is packed with new grease. <br /><br />Regards<br /><br />Chris
