rcarden711
- Sep 14, 2010
- 23
Hello-
I have twin 1999 Mercruiser 3.0LX with Alpha 1 Gen 2 drives. I have the drives and bell housing off to replace bellows and lower shift cables. Since the Sierra bellows kit came with a new gimbal bearing, I was thinking of replacing them even though they both look and feel OK and no water has ever gotten into bellows. However, I accidently used grease w/ teflon on them so I would like to switch them out. I've bought an alignment rod and borrowed a puller and installer.
According to the service manual, I need to install a new grease seal into the the housing before I install gimbal bearing. Am I reading this correctly? If so, I think I need a seperate install tool for that too or can I leave the old grease seal in?
Also, is there a way to tell if the new gimbal bearing is the new style one that doesn't need grease?
Thanks
Thanks
