Gimbal Bearing Parts Question
daidone
sorry for my poor English , I write dall'italia.Se want to remove the pipe 3852564 and close as I do ?
8M2015913 is screwed on the tube or on the house of the bushing ? thank you
daidone
I'm replacing the sealed bearing with that 21752712, and I need to know how to extract the tube 3852564 and plug the hole on the bell , thanks
Fun Times
Hi daidone and thanks as I did receive your private message regarding this question. Lets continue the conversation here vs behind the scenes just in case this topic may help others out in the future.
From my findings, OEM Volvo gimbal bearing part number 21752712 is a "new" (latest model/design) serviceable/greaseable bearing. Since the bearing is now serviceable (again) you will need or want to leave the tube in place that is running between the gimbal housing assembly and the bearing flange/area....You do not want to extract (remove) tube part number 3852564 as you will need it.
There is a chance that if you had a non serviceable bearing at one time, then the zerk fitting where you'd put grease in the bearing (on the side of the gimbal housing) May have had a plug installed...If so, then you would have to remove the plug and re-install a new zerk fitting to use bearing part number 21752712.
With either design bearing installed, you won't want or need to remove the grease tube as that may produce a water leak into the gimbal housing and boat.
Thanks to forum member evantful for his updated info about the new Volvo bearing,
http://forums.iboats.com/forum/engin...d-or-greasable
Hope this helps and let us know what you end up with....Good luck.
daidone
You 8m2015913 KNOW ? USED ​​TO CLOSE THE TUBE 3852564 ? You CAN BE APPLIED DIRECTLY ON THE HOLE ?
if I decide to install the tube 3852564 to use glue ? thanks
Fun Times
if I decide to install the tube 3852564 to use glue ? thanks.
To install either the zerk plug or zerk fitting, you don't have to use any sealant but it won't hurt if you put a small amount on the fitting either.
Here's the directions of how to remove the grease tube, (page 36).... http://www.boatinfo.no/lib/volvo/manuals/sx_dp-s_drive.html#/38
And page 41 tells you how to re-install the tube correctly along with the grease zerk fitting or plug, http://www.boatinfo.no/lib/volvo/manuals/sx_dp-s_drive.html#/42
daidone
Thanks , use bearing 21752712 , as I close the tube 3852564 ? with 8M2015913 ?
