Hello,<br /><br />I bought a 40hp Evinrude Lark 7 last summer and finally have the time to work on it. I do not have the numbers at hand, although it is believed to be a 1965, has Selectric shift and appears to be in great condition still. It has sat outside for 3 years without running, and 8 months in my garage. This is my first boat and outboard, and I know little about them, but I've tinkered around with the electrical and have figured out the junction box and ignition switch wiring. The motor does turn over, the electric starter works great, I believe I got the Selectric shift working, the electric choke solenoid clicks, but I do not know if it is working correctly. There is VERY little rust on the motor itself, although the junction box needed a good cleaning. I have a Seloc 1959-1970 Evinrude manual, and can't really afford parts atm, although I don't think I will need much. So my question is...<br /><br />Where do I look next as far as general maintenance for an old motor and things to check?<br /><br />Also the manual says these take a special lower unit lubricant?<br /><br />Thanks for any help!
