Re: getting my Suzuki dt75 running again after sitting three years
Replce impeller first. Get a manual to do so as it is trickey. The shift rod is attached under the carbs. Pull the carbs at the same time as it will be easy to put the shift rod back once you replace the Impeller. Use small amount of vasoline on the impeller when replacing. <br /><br />Take the carbs down, use gas as a solvent and pressured air to clean all ports / jets. All will come out with 10 mm wrench, clean out all, and all parts with gas, blow out and reinstall with new gaskets, use grease to hold them in place while attaching. Pull the oil container, pull the lines, clean with carb medic through to the intake jets, dum old oil, clean container, fill with new. <br /><br />Pull out plugs, clean or replace, regap, spray into clyinders with liquid wrench, load it up, let stand, turn crank by hand, 5 - 8 revs, the blow out with air, mixe a cup of gas and oil, 4 parts gas, 1 part oil, put 2-3 table spoons in all cylinders, move crank again, Make sure the battory is at full charge. Spray starter down with liquid wrench, by hand, move it, befor reinstall plugs, try to turn it over to see if it has spark, ground plugs to the motor, is good spark, install. Clean off all gas/ oil, install new gas finter, dump all old gas from the tank, pull the hose off the tank, replace if necessary. Pleace the end of the hose into a gas can. Pull off the gas filter, clean, reinstall, pull off inlet hose, pump clean gass through several times, reinstall, now pump up carbs, allow time for the fule to dry off, should start within two or three cranks. If not, pump the carbs up very tight, unitl you hear gas spraying into carbs, then try agin, shoudl start fine. <br /><br />All work will take about 6 hours, more if you are very diligent with cleaning. Make sure to use liquid wrench on all bolts before you start to pull them off. You will go through two - three can of wrench, 4 can air, (unless you have a compressor) and a quart of gas. <br /><br />Good Luck. <br /><br />If you did not learn anything today, you should have stayed in bed. <br /><br />
