Re: Getting boat out of long term storage
For one thing, you should pull the distributor and with an oil pump priming tool, run the oil pump with a drill to circulate some oil to all the bearings in the engine before ever cranking the engine over. Then squirt some oil in the cylinders (a couple tablespoos full will be about right) and crank the engine over with the plugs out to circulate the oil in the cylinders.<br />Then a full tuneup. points,condenser, plugs, cap, rotor, all the usual.<br />Then there is the fuel system. The gas is probably dead after that long. Carb may need to be rebuild filters changed tank drained and refilled.<br />The drive oil should be changed. The ujoint bellows and the raw water pump impeller changed. The ujoints and gimbal bearing inspected and lubed. The alignment should be checked since you have the drive off anyway.<br />Put in new battery/batteries start it up, finish the tuneup. Dwell, timing, advance timing, carb mixture adjustment, idle speed, keeping an eye on the temp and oil pressure.<br />After all warmed up, change the oil and filter. <br />Run it again, check the shifting. IF it dies when you put it in gear and take it out of gear the shift cable is probably due to be changed too. So to keep from pulling the drive twice, you may want to change it while changing the bellows.<br />Now, if everything has gone perfect you should be ready for the water. But on boats, there ain't no such thing as perfect. But you will at least have some idea what else will be needed at this point.
