getting a warning at 3000 rpm's
walker1
was cruising in my boat at 3000 rpm's and the warning beeper went off and noticed the temp gauge was going from 100 to about 150 and when i slowed down the temp stabilized at about 150, does that indicate a bad themostat?
Don S
Re: getting a warning at 3000 rpm's
Since every boat and power package is NOT the same, how about letting us in on what you have. Engine Make, Model Number, Year, even a serial number.Along with drive type, make and model.
All alarms systems are not created equal.
walker1
I have a 1998 mercruiser 5.0 ltr/250hp with an alpha1.
Don S
Mercrisers had the same alarm for 3 things. Low oil pressure, High coolant temp, and low gear lube monitor.
Since the temp alarm shouldn't go off till about 200°, I would be looking at the gear lube monitor. Is it low?
When the alarm goes off, disconnect one at a time till the alarm goes off. That is probably the offendng sender.
