Hey gang,Posted here a few months back with some carb rebuild questions on my 65 Johnson 40 hp and 62 Crestliner which helped immensely and was a success!
Had the boat out on the water today and experienced some issues.
Trip began fine with ampmeter reporting a good postive charge once I had my RPM's up and throttle about 1/2 open. However, shortly into the trip the meter read zero (to a slight negative) and there was a clicking/ticking sound that came from the junction box at the rear of the boat.
The tick tick tick increased or decreased in frequency with throttle adjustment. Disappeared at slow idle, but any type of forward throttle produced the tick tick tick (wife asked if some had planted a bomb on the boat lol). I listened close and it definitely was not the motor, but instead inside of the junction box. I had a peak inside, and on the removable cover was what I assume is a regulator with ARM FLD and BAT leads going in.
So I guess I'm trying to figure out what to do next. Is this an alternator/generator side issue, or a regulator failure. And if it's a regulator failure, can I even find these parts still? I've taken a pic of both the generator and regulator components that are listed as 'Prestolite'.
Thanks guys. Appreciate and suggestions/troubleshooting. In the meantime I'll run with a spare fully charged batt on board to ensure restarts (the rip cord is a beeyotch to try and tank on this ole gal).
