Re: gel seal
One thing I have found with gel-seal is that the surface must be perfectly clean with all old traces of gel-seal removed. I buy the small tubes, and only use fresh un-opened tubes for each engine. You can also make up a black-lite to make sure the surface is clean, and be sure to use the primer.
