Intoodeeep
- Aug 13, 2011
- 64
I gel sealed my block today. The spray activator I used was a couple years old. I couldn't find anything as for information as a expiration date on this stuff but wanted some thoughts on this as well. Second is that I confused my torque specs when torquing the block. So I torqued it to 10 ft lbs originally, and then two and half hours later found the right torque specs of 20 ft lbs and re-torqued them to the correct specs. I didn't realize they were called main bearing bolts and confused them with the lower bearing for some reason from the way the manual was set up. So I now have a different issue and have to replace the lower bearing plate. But basically is the gel seal going to hold? The gel seal I used was loctite 518 and is brand new.
