Gel Coat Crack Inside Ski Storage
eskimko
This is my first post here, but I have been reading discussion for a long time, especially while I was doing research for buying my first boat. After months of research, hundreds of boats seen I finally settled for a Four Winns H190 2008. The boat looked flawless, engine had low hours, no scratches, no dents, no gel coat crack on the hull, leather seats looked brand new, overall I thought that I scored the perfect deal.
The boat was purchased one month ago, had in water half a dozen times and was very happy. Today I decided to clean it completely, removed snap on carpet and almost got a heart attack.
Inside the ski storage compartment which is located below the deck there is a gel coat crack, and also gel coat chip 1.5"x2". With this being my first boat I am not even sure how serious this is. Since it is inside the dry compartment and not exposed to the direct sunlight I am trying to calm myself down and convince that it is nothing to worry about, on the other hand I read some scary stories about gel coat crack. I am not even sure if I should be worry going boating? Should I pay somebody to fix it? Or can I do it? Attached are few photos, hoping that somebody can give me an advice.
Re: Gel Coat Crack Inside Ski Storage
Hi, and welcome. Personally, I wouldn't worry about it. Probably caused by careless storage of ski's by PO. You can buy gelcoat repair kits and patch it yourself. Won't be cosmetically pretty, but it's out of sight :)
Nothing to worry about. That's merely a cosmetic bruise. Repair it if you want, but somewhere along the way it'll probably get more rash like that anyway.
smokeonthewater
agreed... also the seats are vinyl... don't use any leather products on them
eskimko
Thank you all. At least I will be able to sleep :). As I said I am a boat rookie and trying to learn by going with the famous saying " there is no stupid question...".
Thanks for the leather tip, another rookie mistake.
Home Cookin'
straight to the junk yard!
In this way boats are like cars: they will have scratches, dings and nicks. Just worry about the ones below the water line, and even that's not the end of the world until you get a chance to fix it.
Yacht Dr.
Its just a few " Air Voids " .. Dunno why anyone else didnt pic up on this ..
If you can get them fixed under warranty then great .. Your boat is not going to take on serious damage from these little things ( every boat has them ).
Your boat is not the only one to the air void thing .. every boat has them .. you just have to get lucky sometimes to find them if your not looking for them ;) ..
YD.
