gears
cacy
My father has finally got the hitch pin back in place however he can not now get all of the gears to work. The forward might work but then the reverse will not work.<br />Any advice?
adrian bick
Re: gears
The shift rod has to be set at a precise height above the gear case before assembly . Check the manual. If you do not have a manual better get one .
