Re: Gearcase or Spun Prop Issue?
I do not think it is an hydroelectric shift motor based on another thread I read from "Seahorse" that reads. "If you have a prop with a drive pin (shear pin) in it, you have the electric shift gearcase, with springs and electro-magnets." I have a shear pin. It shifts into gear fine but, seems to slip when I accerate the throttle. ***One operating difference over the span of two weekend is... on weekend one I had the motor running fine attached to the 12 volt battery, whereas weekend two I ran it without the battery as it was dead and the issue surfaced after a few minutes of planning near full speed. Does shifting require the battery?
