Re: gearbox disassembly?
Disassembly basics while you are waiting for the manual: Drain oil. Take off propeller. Remove two screws holding on anti-corrosion anode behind propeller. Remove four screws holding spool inside case. Don't lose O-rings behind washers. Buy new ones for re-assembly. Make a puller out of 1/4 all thread to pull out spool. Remove the two half rings holding in the reverse gear carrier. Use 5/16 all thread to pull out carrier. Pull out drive shaft, reverse gear, and dog clutch as an assembly. Brass yoke for shifting may fall off the shift shaft. If so, fish it out from behind the forward gear.
