henning_dt85
- Oct 19, 2003
- 74
Tuned up my 10hp Johnson 1960. Removed the skeg and ut it bak together. I tryed it last night and the gear troubled. First I sat it in reverse, and nothing happened ( I tought it was the shift rod connector. It worked fine in Forward. I pulled it bak to neutral and it didnt shift. I pulled it into reverse again and it shifted into reverse. When I pulled it back to N it stopped. Pulled it into Forward again and nothing happened. What can be the problem?
