The gearshift is stuck in forward gear on my 1984 35hp Johnson Seahorse. This happened when I took the motor off to make it easier to move the boat across the shingle to it's new mooring, was in neutral when taken off, but got moved to forwards in the move (shift leaver is now a bit further forward than originally). I don't think it is the gearbox as when I undo the linkage at the water intake the gears are shifted to neutral but the shift rod is rigid. The gears are pulled back to forwards again when I reconnect. I suspect the gear shift rod has somehow jammed under the power head, does anyone know if this is this difficult to take apart or will I have to take it to a shop?
Many Thanks
Dave
Many Thanks
Dave
