1976 888 Mercruiser I/O. Recently replaced water pump impeller and exhaust bellows. Upon reassembly of outdrive onto boat, I've noticed the following: 1) Engine off, boat out of water, in reverse gear - I can rotate prop in both directions by hand (it should be locked in one direction). It makes a clicking noise upon rotation both directions. 2) Engine off in neutral - When spinning the prop by hand, a distinct clicking sound is heard, like the clutch dogs are trying to engage. I can move the throttle back and forth a few times and sometimes the prop will spin freely (no clicking) 3) Engine on, when bringing throttle back to idle from foward, the same clicking can be felt in the throttle lever. <br />Any thoughts would be appreciated. Thanks Rich
