77 Johnson 115 .... When I go to put the dame thing into gear it will just click like it is trying to go into gear. I used a pair of pliers and helped and it went but will quickly jump out. Adjusted the cabel and nothing. My thinking is it is hydrolic shift assist thingy or gears that have something to do with the shift assist. I even lowered the RPMS all the way down tell it would almost die like 600 and same thing. It will go right into reverse. Any help before I take the lower unit apart and mess that up. Have not noticed any shavings in the gear lube. This motor rebuild has giving me hell.. :|
