Gear ol vent hole blocked
Mikelisi
I was pumping gear oil into my 3.5hp Nissan and the oil started to come out the flange above the lower gear housing.
Does this mean I have an oil seal leak or is the pressure of the oil pump too much for the seals to handle? I was using a hand oil pump.
Also how do I unclog the upper oil vent?
Mike
Grub54891
Re: Gear ol vent hole blocked
There should be 2 screws in the gearbox. One at the bottom for draining and filling. The upper screw is the one you take out when filling,pump till oil comes out of the top hole,put the screw back in with new gasket,the remove the bump and quicly install the bottom one with a new gasket.hopefully ya didn't blow the top seal out. I'd pressure check it before re-doing.
