Is it ok to use any 80-90 W gear oil in a 120 mercruiser drive.
D dougdef Cadet Joined Jun 3, 2009 Messages 6 Jun 11, 2009 #1 Is it ok to use any 80-90 W gear oil in a 120 mercruiser drive.
D dougdef Cadet Joined Jun 3, 2009 Messages 6 Jun 11, 2009 #3 Re: gear oil I used synthetic, but now i just use reg. gear oil to much $$$.
Haut Medoc Supreme Mariner Joined Jun 29, 2004 Messages 10,645 Jun 11, 2009 #4 Re: gear oil Mercruiser gear lube is ten backs a quart, once a year..... You must really be on a tight budget.....
D dougdef Cadet Joined Jun 3, 2009 Messages 6 Jun 11, 2009 #5 Re: gear oil yes, hard times these days.
Mkos1980 Chief Petty Officer Joined Oct 25, 2007 Messages 640 Jun 11, 2009 #6 Re: gear oil Ditto to the above, MerCruisers high Performance Gear Lube is where its at!
sickwilly Lieutenant Junior Grade Joined Jul 9, 2007 Messages 1,089 Jun 11, 2009 #7 Re: gear oil Quicksilver high performance gear lube for me. I think its absolutely the same stuff, just a different color bottle and sold somewhere else.
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,366 Jun 11, 2009 #8 Re: gear oil Ayuh,.... Any good clean hypiod oil will Work,.... Personally,... I see the Synthetics worth the extra ca$h... I run Mobil 1, in 75W-90....
