Gear Oil leaking out of Water Intake
jnewtonsem
Noticed my 30hp Nissan has gear oil leaking out of the water intake. Left about a 6" spot on the driveway. Last time I ran the engine was to flush with muffs with some salt protector for running in salt water. Don't believe it was leaking prior to that. I'm assuming I've blow a seal between the gearcase and water pump. Any suggestions?
TOHATSU GURU
Re: Gear Oil leaking out of Water Intake
Is it black oil or is it gray or amber?
jnewtonsem
More of an amber color. Looks almost like motor oil.
TOHATSU GURU
Probably a propshaft seal, but you need to have someone pressure test the lowerunit.
jnewtonsem
Thanks Elvin Have got someone lined up to look at it.
