rib4charter
- Jun 3, 2008
- 26
My port engine which is a 75 HP Honda 4 stroke is weeping gear oil out what looks to be a small weep hole in front of the oil fill screw opening where you fill the lower unit. I had these serviced in September and never noticed a leak until I put the engines in the down position on the trailer and it just dribbling out. Is there a seal that let go there in the lower unit? Is that just overflow? I opened up the oil fill opening and it was completely full. Anythoughts?
