kwoolard
- Feb 9, 2003
- 420
Hey guys,
Over the past two seasons I've noticed that my gear oil in the reservoir drops slightly over the year during use, to where i have to add enough to bring it up from the low level line to the fill line. I know it is probably the yoke seal after reading other posts in this forum. After removing the drive the past two winters I've noticed a small amount of gear oil (4oz. or so) in the bellows. So today I decided to pressure test the drive to make sure that the seal is in fact leaking.
I turns out the drive held 15psi for 10 hours today without dropping a smidgen, even while rotating the u-joint shaft I sprayed a soap solution looking for leaks and didn't see any. I assume that this is now only leaking when the drive oil is warm.
Questions are:
1) Does this warrant a yoke seal replacement even though no visible leak is present? (I can't figure out any other place oil could get in the bellows)
2) Assuming I have the bearing set that requires the rolling torque method, is this something a certified shop should attempt and then again, should I trust them to be certain to set the torque correctly? Or is this something a decent shade tree could perform...such as myself...I don't have a dial type torque wrench but could probably get my hands on one?
3) Is it absolutely necessary to remove the top cover of the upper gear case or can this repair be performed without removing the top cover? (Looking at the exploded parts view I don't see it necessary, but the O&M manual is unclear as to whether the cover needs to be removed.
4) With the yoke assembly out and even though I have no u-joint problems, should I go ahead and replace the permalube u-joints with the greasable type?
thanks,
Keith
Questions are:
thanks,
Keith
