I have gear oil in my bilge I changed the lower unit lube near the end of the season. when I was getting the boat ready for this seasion I noticed the small bottle with additionl fluid was low and I found fresh gear lube in the bilge. When I changed the lube I pinched off the tube from the bottom of the bottle filled the lower unit up from the bottem hole replaced the top air vent screw and unpinched the hose and topped of the bottle. I do not see any oil at all on the transum inside or out and the lower unit is not leaking. There is oil under the bottle on the bracket it sits on. any help would be great This is on a bravo 3 with a merc 350 EFI moter in a Crownline 225 the year is 01.
