Gear oil in Exhaust Bellow - Alpha One
billfred
I noticed after this winter gear oil leaking from the very bottom of my gimble housing (from the one inch diam hole). I made the mistake of storing my outdrive in the up position, and I don't think I drained the gear oil.
I took of the outdrive today and I noticed alot of gear oil in the exhust boot. I'm guessing a seal allowed gear oil to drain back into the boot then down into the gimble housing.
Can someone suggest what seal I should be looking to replace?
alldodge
Do you have a drive lube bottle?
If so is the bottle low or empty?
If so check the seal between the drive and bell housing
