gear oil access on 89 Merc 9.9
sandman66
Just purchased a used 1989 Merc 9.9 outboard. Want to put in fresh gear oil but can only find the drain plug. Is there not a upper plug to determine when it's full?
I noticed a piece of dark putty stuck underneath the "flat" part of the leg. Is this from the factory or did the guy use this to cover up a defect? It about 3/8" wide and about 1 1/2" long, just under the planer part of the leg on the left side (if you were in the operator position)
