I have a 1973 140 hp mercruiser I/o got it for a few hundred dollars. Po could not get it started. Changed the points got spark. Carb flooding. Rebuilt it with new float. The old one had a hole and was filled with gas. After that it would just back fire from carb. The distributor cap was in the correct firing order but all the plugs were moved over one spot. Fixed that she fires up every time now.
Next no forward or reverse. Took lower shift cable off didn't move at all with the plastic end off so figured I need a new shift cable. Was taking the drive off to see if anyone updated to the newer cable they did. And there was just some goopy stuff n there and it moves freely again. Probably still going to switch it. Newest problem, the u joint bellows was full of gear lube which I know is the seal and I understand that I can buy a seal kit and the tool. But there was random chuncks of metal in the oil a few piece came off the the metal sleeve the bellow sit on and were probably smoothed out from riding around in it two were the grease points for the ujoint which means new u joint and yoke. The last thing is a tiny spring and then two things I can't identify. Can anyone identify the two pices and tell me where they came from and where the spring came from and what those other two are How bad is it and can I fix it. Ps how do you upload a picture from a cellphone
