Gear Lube in Bilge
majphill
This summer, I replaced the lower half on my Mercruiser Alpha one. Every time I went to put the boat on the water, I would check my gear lube level to make sure it was full. I would always need to add about 6 or 8 oz for it to register on the dipstick. I replaced the o-rings around the dipstick and drainhole to no avail. Finally I noticed oil in my bilge, which appears to be the gear lube. I keep my boat on a trailer with the trim up. Is there a seal that is the likely culprit? It ran perfectly all season, but it's making my bilge a mess.
tommays
Re: Gear Lube in Bilge
I would say that the drive shaft yoke seal is leaking oil into the bellows and has filled it up
When the drive is pulled make sure you have something to catch the mess because it sounds like you have a few quarts of oil in the belllows :)
Tommays
bruceb58
How often do you pull your drive to inspect your u-joints and gimbal bearing? You should be doing this yearly and will notice any gear lube in there.
