Smokygrayson
- May 22, 2011
- 17
Hi all.
On the lake on the weekend, the motor starting jumping out of gear (at any speed) and then back into gear.
In the end, it jumped right out, and the linkages and gear lever connected to the forward controls came off. The gear lever was still attached to the forward control wire.
I took the cowling off - the linkages between the lever and the motor had become disconnected. But inside the linkages there is a spring which kept pushing the lever off the end when I put it back on again.
Does anyone know what has happened here? Should there be something that holds the lever onto the motor housing or to the other linkages?
Thanks for any help.
