Gear case flush
JohnKS
Hi folks: 1985 30 hp Johnson working fine. I'm changing the oil in the gear case for the upcoming season and thought I'd flush the gear case before I put in fresh oil. What would you suggest as a flush - don't want to compromise the seals.
Cheers, John
kenmyfam
Re: Gear case flush
What did the oil you drained look like ???
JohnKS
Re: Gear case flush
Hi: looked just fine. A little dark but you could see through it. No signs of emulsion or water globules.
Texasmark
Re: Gear case flush
So why flush. "Don't fix it if it ain't broke......."
Mark
Vic.S
Re: Gear case flush
Agree, let it drain and refill. If its "clear and bright" its OK. Most oils darken a bit in service.
If it had water in it I'd suggest a flush with cheap automotive engine oil drain well and refill
Dont forget .... new seals on the drain and level plugs
Texasmark
Re: Gear case flush
So, where are you with your "fix". We don't just balb, we want to know how you are doing.
Mark
kenmyfam
Re: Gear case flush
Agree with the others. No need to flush if all appears well. New seals every time though.
JohnKS
Re: Gear case flush
Appreciate your replies and advice. New plug seals and refill - that's it. Thanks again.
All the best. John
