When draning gear lube for winter,1979 25 Hp Evinrude electric start, much water not much lubricant. During summer I noticed lube coming from weep hole near oil level plug, I am assuming bad seal in top of gear case around drive shaft, any thoughts on this,how difficult is repair? Any special tools required? I have replaced gears in gear case, but never got into any further teardown. I am sure water not coming in around gear case seal. Any help would be appreciated any place on web that might walk you thru repair, maybe with pictures. Thanks swede
