hastingsml
- Oct 7, 2005
- 19
I am buying a boat that has gate valves that I plan to replace with ball valves. Currently there is a thru hull with the gate valve screwed on. The valve is the type that does not screw all the way down to the inside hull.<br /><br />I have notices two types of ball valves. One has a flange that actually becomes part of the thru hull and tightens down to the inside hull. The other does not have the flange and just tightens down on the threads of the thru hull.<br /><br />Should I just remove the gate valve and screw on a ball valve or remove the inside fitting of the thru hull and attach a ball valve with the flange and seal/tighten it down to the inside hull?
