eeboater
- Jul 19, 2004
- 2,644
I need some advice/recommendations from the wise folks on our board here. Over the weekend, I put solid sides on my 4x8 utility trailer that I use for general purposes around the house. I am 90% done and am now confronted with what I should do about securing the rear gate. Up until now, I used a flimsy clip to hold the rear gate on. As you can see from the photo below, the rear gate was pretty light as it was just a couple 1x4's held together by two 2x4's. Well, now the sides are 1/2" plywood and much heavier. And I am afraid of leaving the gate to be secured to the back of the trailer by the two pieces of 2x4 that are stuck into the lower braces. <br /><br />What do you guys do to hold the rear gates of your trailers on? I was thinking about putting two eye bolts on each side - one on the gate and one on the side of the trailer then running a bungee across the two. But, for some reason that idea is not resonating that well for me. There was another idea of putting two guides on the inside of each wall which would allow me to physically slide the gate into place. But I am not too keen on that idea because the plywood could have the tendency to bend and as such dislodge the gate. The third option is something like this:<br /><br /> http://www.etrailer.com/Merchant2/m...e_Code=E&Product_Code=383200&Category_Code=rb <br /><br />But OUCH - 30 bucks a piece, for something that is WAY overboard. <br /><br />Any Ideas?<br /><br />Thanks,<br />Sean<br /><br />
