gasket
dbocha01
Rebuilding a Mercruiser I , 150 HP, 1966-67 (?) sn2020415
Do I need a gasket between the upper and lower units of the sterndrive?
Fishermark
Re: gasket
There is no gasket between the upper and lower. BUT there is a "quad ring" - it is like an o-ring that seals the oil passage between the two halves.
dbocha01
Re: gasket
where is the quad ring then, i didnt think oil went between the two halves of this model.....I have an oil fill and vent plug on top half and bottom half
Apollo75
Re: gasket
Looking from the rear it is on the right side about even with the water pump in a little 3/8" or so wide grove cut into the lower unit top housing.
There is an oil lube passage from the top to the bottom units --- this little ring seals the passage.
OFM
If the boat is not sinking or on fire, Relax :D
dbocha01
Re: gasket
I didnt see this oil passage....will it hurt anything if I cat a gasket and put it between the two halves?
Fishermark
Re: gasket
You don't need to cut any gaskets - BUT YOU DO NEED THE QUAD RING. There really is an oil passage there. I will try to find and post a picture.
Apollo75
Re: gasket
Great job JustJason :D
I learned something today :)
OFM
JustJason
Re: gasket
Ayuh,... Leave it to the Kid to know about the Antique drive's peculiarities,....
That was just useless fact #21557824 that was floating in my brain when I stumbled upon this thread.
You think i'm a nerd now... you should see me yell at the tv when i'm watchig Jeopardy.
Fishermark
Re: gasket
Oops! Well, I didn't read the link that Jason shows yet, but I guess I need to go back and do some more reading myself! :redface:
dbocha01
Re: gasket
Thanks Jason....there def is not an oil passage...I inspected it last night closely, after wire brushing and scraping with a razor, no hole. Ok so no gasket between the two halves then. Thanks guys
