Hello Guys,
I have a 77 Johnson 35hp 35e77c. Leaks fuel from where the air silencer attaches to the carb. There are two gaskets that sit between the air silencer, air silencer support, and the carb. Is it ok to use gasket sealer on these gaskets? If some gasket sealer got into the fuel mix, would that gum up the engine? Also, is it ok to run a bead of marine silicone around the air silencer halves to seal it up?
I definitely want to check what sealers are ok to have that close to the intake on the carb.
Also, could you retro-fit a later model carb on an older engine? It looks like the carb for the 1993 Johnson 35hp's would fit the 1977 35hp. Just out of curiosity.
Thanks for your help. You guys have helped me keep my engine running very smoothly-Jeff.
