I just replaced the lower unit on my Alpha One Gen 1 outdrive. I installed a new water pump assembly and put it back together, put fresh oil in it, pressure tested it and figured, good to go. Then I remembered that I forgot to put sealent on the pump gaskets! Do I need to tear it apart again and seal the gaskets or can I let it be? <br />Thanks!
