Gasket sealant
kevinwd1
I'm about to replace the thermostat on my Tohatsu outboard and was wondering if you use gasket sealant in conjunction with a new gasket?
​Regards Kevin
pvanv
As long as the gasket cap and mating surface on the motor are 100% perfect, you probably don't need any extra sealant. If in doubt, a TINY bit of sealer (even marine grade silicone) is OK. Be sure to tighten the cap bolts gently and evenly to avoid cracking the cap.
Sea Rider
Be sure to remove all gasket leftovers from both sides of thermo housing, gently file both sides with fine metal particles sand paper, no need to use silicone on new gaskets, usually sits nicely on flat even surfaces when cap is evenly adjusted.
Happy Boating
kevinwd1
Replaced thermostat today and it was jammed open with alot of salt build-up. Is flushing with fresh water enough to remove salt or do use products such as salt away?
pvanv
Fresh water will prevent buildup, but probably will not remove scale. Vinegar works OK, or you may need to disassemble and mechanically scrape the deposits out. What motor is this, and does it now overheat?
Sea Rider
That's why need to flush engine for at least 3-5 minutres after each outing specially if engine operates on salty waters, nevertheless although flushing should take care of salt deposits, it must be removed from time to time to have a flawless operation as you will always find adhered thin salt deposits on thermo due to constant on/off, cold/warm temp engine cycles.
When removing thermo for maintenance, do it gentle as not to damage thermo's upper rubber ring that can be damaged easily, soak thermo in pure vinegar for at least 15 minutes, gently scrape salt off with a stiff toothbrush around spring amd plunger as well, put back along a new gasket.
If heavily salted, crusted or corrroded put a new one in, engine will cool much better. Before doing so, remove all salt deposits on cylinder head thermo seat, apply water grease to seat & thermo's upper round rubber ring, that way will be much easier to pull out next time you want to perform a preventive maintenance.
Happy Boating
kevinwd1
I took the boat out today and it pumped more water and was definitely cooler. So thanks Sea Rider for suggesting changing thermostat as it was needed
