Re: Gas
Hi,<br />If your timming is set at 21der at wot use regular gas. I use premium in mine any way. The fuel today drops in octain rating in 2 wks. So I error on the side of more octain. DO NOT RUN THE<br />MID GRADE WITH ALCOHOL IN IT!!!!!!!!! You will<br />melt the no 1,3,5 pistons. BYW if your timming is set at 23 degrees back it down to 21 now.
