Re: Gas Tanks Up Front in bow for 75HP outboard,is this ok to do?
Putting your tanks in the front is no problem, however I would recommend you use the next size up in fuelline, 3/8" probably. Also you should have the primer bulb nearer the engine, not the tanks. If you have any doubts, set it up and run the engine with a vacuum gauge attached to a tee-piece at the fuel pump. It shouldn't be pulling any more than a 2" vacuum.
Chris.....
