gas tanks in bow of pontoon boat
pjnermoe
will my 4 cycle honda 75 hp pump gas from gas tanks in the bow of my pontoon boat 30 feet away ?
Bronlonius
Re: gas tanks in bow of pontoon boat
Probably will work fine as long as everything is tight. I have 2 front mounted 3 gallon tanks in my 12' boat. I ran a steel line under the floor, and put a rubber hose with quick connects on each end. I put the primer ball hose right by the motor, so it draws fuel from back there.
